Just wondered what peoples choice was for backing up their DVDs,
and whats the best program for ripping just the movie and the menus? Iliked the look of DVDshrink but you can actually remove the extras that you dont want, can you?
MenuEdit or DVDStripper may be used to remove bits and pieces of the disk you don't like. MenuEdit will go one step further and disable buttons linking to removed material.
My favourite is DVD Shrink followed by Nero to burn the finished backup, and yes you can remove unwanted items in DVD Shrink.
Artificial intelligence is no match for natural stupidity. -
DVDshrink
only problem i have found is v3.0b5 does not like the output of TMPGEnc DVD Author. it always gives me an error (error unknown) either immediately or in the middle of the initial analysis. luckily i found a workaround.
Just got my Pioneer Ao6/106 today from Novatech + 25 Novatech DVD-R (4x) for £115
Got the old cd/rw out put the DVD-RW in, no probs at all.
Backed up Charlies Angels 2 onto 1 DVD-r using CloneDVD, dropped all extras bar 3 featurettes, allowing movie to be kept at 100% quality.
It took 29 mins to do the whole transcoding and burning, popped in Standalone and its a perfect back up,
Looks spotless!
thanks for your help! -
DVD Decrypter (free) to rip and InstantCopy 8 (about $35 at Buy.com) to squeeze and burn. InstantCopy 8 makes the best quality squeezed DVD's bar none. Download the trial. The quality of even a full 8+g squeeze will surprise you. Go Movie Only, and you'll be in heaven.
Whats the best DVD Authoring software for me please!!
By stefanj in forum Newbie / General discussionsReplies: 3Last Post: 20th Apr 2010, 13:10 -
Which prog to get audio to work on DVD?
By bytheway in forum Newbie / General discussionsReplies: 2Last Post: 3rd Apr 2008, 19:40 -
DVD to PSP, whats the easiest way to do it?
By Nick1982 in forum Newbie / General discussionsReplies: 0Last Post: 8th Jul 2007, 06:45 -
Whats the best DVD burning program out there?
By Tielurr in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 18:21 -
whats the best CD/DVD burner reader out there right now?
By econtrerasguzman in forum ComputerReplies: 8Last Post: 8th May 2007, 14:58
