I have been trying to rip a dvd I ran it through smart ripper and dvd2avi right by the books but tmpg wont recognize the video file (D2V)it will recognize the audio file though. i TRIED D/L THE LATEST VERSIOON AND HAVE ALL the plugins???? I f any body has any advice let me know.
You might have downloaded and installed the VFAPI Plugin for TMPGEnc, but are you sure you installed it into the same directory as TMPGEnc and executed the *.bat file?
Will it not recognize the D2V file or will tmpegenc not allow you to choose the the D2V file. If it won't let you choose the D2V file, you have to go under "environmental settings" and check the option that allows you to choose audio and video from two different files. The exact option escapes me at the moment but I'm sure you'll see what I'm talking about once you look.
I have the same problem!!
I´ve already converted a couple of movies this
way but now it won`t work anymore.
help would be very nice.
it won`t open the d2v file ( not suported )
GOOSE
<font size=-1>[ This Message was edited by: goose on 2001-07-11 14:20:34 ]</font> -
open the D2V file with notepad and check that it is pointing to the right path where the actual VOB files are.
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33
