Hey there all, i've been searching through massive amounts of forums and still can't get an answer.
My question is, how do i put 2 dvd movies onto 1 dvdr with menus?
For example, let's say Ace Ventura Pet Detective and Ace Ventura When Nature Calls. I ripped these 2 dvd's each, and then combined them both using DVDshrink. Now i want to make a dvd menu that'll select either of the 2 at the beginning instead of forwarding till the end of the first movie to get to the second dvd. I just want to make something very plain and simple, 2 buttons one for the 1st movie and 1 for the second movie.
thank you all for your time in reading this. i've gotten tons of information through this site and i thank you all for your efforts again.
I use Tmpgenc DVD Author. It has a button to import files directly from a DVD or from the DVD files that have been created on your computer (by DVD shrink for instance). You can then add or change chapters and menus and it will even burn the DVD for you. There are freeware ways to do it but I don't think any are as easy and reliable as Tmpgenc DVD Author (with a name like Tmpgenc DVD Author... it has to be good!)
Backed up VHS tapes on one DVD, need to create menu DVD
By perceptionist in forum Newbie / General discussionsReplies: 6Last Post: 11th Mar 2011, 18:57 -
How to create movies that is playable in home DVD players from a movie DVD
By vain in forum Video ConversionReplies: 2Last Post: 16th Mar 2009, 02:10 -
Number of Different Programs used to create your DVD movies?
By Jedi5 in forum Newbie / General discussionsReplies: 18Last Post: 7th May 2008, 19:36 -
create menu for 2 movies with several vob files with guifordvdauthor
By aruwin in forum Authoring (DVD)Replies: 1Last Post: 30th Dec 2007, 06:22 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
