Hi!
I an very pleased with my pioneer dv-343 but there is nothing in the manual that tells you how to switch PBC on/off, anyone know?? Is PBC the reason why I get short disturbances in the sound every chapter on DVD? Also, when playing SVCD I just can`t figure out how to get to a specific time on the cd, kind of slow to use the fast forward button. Does anyone know if there is a "goto" or "search" function that works with SVCD?
/Swede
With Pioneers you have to press stop or something, then play again. I dont know if that right but it is fairly easy to get it to show the time. Just play around with the remote a bit, you'll work it out.
Swede,
I have a DV-333, so hopefully it's the same. Put the disc in the player and instead of pressing play, press the track forward button. Hopefully that will help.
SH
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 16:27 -
Search Excel Spredsheet Data in Vista Search
By mn072065 in forum ComputerReplies: 11Last Post: 29th May 2009, 00:26 -
Question about search engines that search Rapidshare
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 9th Nov 2008, 03:08 -
Philips DVP 5982 Time Search Question
By TufrThanu in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Oct 2007, 15:05 -
Is it possible to 'Time search' through Divx files on Philips 5960?
By Kibz25 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Aug 2007, 10:15
