  1. Is 99 the max slides you can have to a slide show? Weird, I thought you would be able to have as many as you like
  2. What program are you refering to?? Some can have 99 pictures in 99 slideshows. That 9801 pictures!!!
  3. MyDVD does have the 99 limit per slide show, but I have been using multi shows without problem. The shows will play one after another.
    I was trying to play cheap by putting photos on VCD's, for which the limit of total number of files on disc is even worst, 250 or something close.
