How do you get a .bin and .cue converted to dvd?
Now its the time to live, fight and to steal a kiss.
-Refused -
This is a strange question. The bin/cue files are a "CD image" that's
intended to be burned on a CD-R, not a DVD-R.
DVD burners can also burn CDs and CD-Rs are cheaper then DVD-Rs.
So what's the point of using a DVD if you only need a CD ?
Anyway, if what you want to do is extracting the files from the CD image
and burn them to a DVD, here's how I would do it:
1) Add a "virtual CD drive" in your windows explorer and "mount" the
bin/cue image on this drive. You could do it with daemontools, which
is a free software.
2) You can now access the files directly from any application using the
drive letter of the virtual CD. Thus you can copy them on your HD or
burn them on a DVD using your favorite DVD burning software. -
AFAIK, it could be a DVD image as well. Just burn it - to DVD.
/Mats
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
