I get Multicopy.exe error. I have seen some threads how to fix it. I tried but couldn't.
Is there any other software I can use?
Results 1 to 24 of 24
A broad question like that is a little like calling your doctor on the phone, telling him you got hurt and expecting him to tell you how to fix the unspecified injury.
What are you trying to do when you get the error? Do you get it everytime you try to use it? Which version? -
BObk,
Here are some details which I didn't say...
1. When I copy a DVD which is less than 4.7 GB ( using Roxio Software ), never I face any problem. No Complaints.
2. Roxio does copy DVDs more than 4.7 GB. Any one knows if the latest one does?
3. Now, If the DVD is more than 4.7 GB I use Instant Copy 7.1.X . This works fine for some movies and for some movies I get MultiCopy.exe error. Here the quality is good for the films I could complete succssfully.
Now the question is there any way to fix the issue?
4. Then I downloaded the DVD X COPY trail version. This one successfully burns the DVD (>4.7GB) but I can't play in my DVD player, DVD-ROM. Only my DVD+RW can play it. The Video Quality sucks. Did anyone face the same problem?
5. Now I would like to know any other softwares which can burn DVDs which are greater than > 4.7GB.
Thanks -
what is the exact error it reports?. Is it the one that wants to send to MS?
can you take a snapshot?
IC7 with the hack can remove titles but DVDShrink can't. I guess sometmes free ain't the best option for people. If it was wouldn't everyone be using the free tools all the time? There would be no need for commercial software as most stuff out there can be done for free if you look hard enough and decide to put a little effort in
. Then again time and effort ain't 'free'
don't get me wrong I love DVDShrink
and I loved IC (once), I just use whatever suits my needs at the time
I can't help much unless you can post a pic of that error or copy it to a text file when you view the details of it
does it always happen in the same place?
more details may give me a better idea of what it is -
MackemX
whether a title is removed in IC, or not included in the re-authoring window in shrink...isn't the end result the same (all other things being equal)? are we just splitting hairs here? -
????????Originally Posted by noki
we ain't splitting hairs, you've made a simple mistake
where did I say I was removing menu's?
I was wondering what you mean't
"Roxio does copy DVDs more than 4.7 GB. Any one knows if the latest one does?"
The latest Roxio does not copy DVDs more than 4.7 GB. I don't think anything will copy a DVD of more than 4.7 GB to a 4.7 DVD without compression.
"Now, If the DVD is more than 4.7 GB I use Instant Copy 7.1.X . This works fine for some movies and for some movies I get MultiCopy.exe error. Here the quality is good for the films I could complete succssfully.
Now the question is there any way to fix the issue?"
Here's what I usually do. It works for me: DVDDecrypter to rip all files in file mode. DVDShrink to get rid of unwanted stuff and shrink it to around 4.2 GB (I avoid burning much over 4.2 GB- that seems to eliminate a lot of problems I used to have with disks freezing near the end). After shinking I burn with either Nero or Instant Copy- if Instant Copy I create the .pdi file first, then burn from that. (I use Nero when I'm using +R disks- for some reason IC doesn't like to burn +R in my system).
"Then I downloaded the DVD X COPY trail version. This one successfully burns the DVD (>4.7GB) but I can't play in my DVD player, DVD-ROM. Only my DVD+RW can play it. The Video Quality sucks. Did anyone face the same problem?"
I used DVDXCopy for about 4 months earlier this year. I preferred DVDXCopy Xpress until I started using DVDShrink.
"Now I would like to know any other softwares which can burn DVDs which are greater than > 4.7GB."
I'm not sure what you mean by that. If you have a DVD more than 4.7 GB you can't burn it to a 4.7 GB DVD without making the files smaller or eliminating some of them. -
"noki wrote:
MackemX
where did I say I was removing menu's?"
Why are you asking about menu's? He didn't say anything about menus. DVDShink will let you remove titles. You can set the start and end point and use any title or part of a title that you want. -
??????????? lolOriginally Posted by BobK
, I'll play
Don't the vast majority of DVD's have menus? Therefore wouldn't removing titles from a DVD would leave menu's. You can twist it anyway you want if you like
I think you already know this but this is just in case you don't. If people want to strip menu's from a DVD then they normally ask 'how do I make a movie-only?' or ask 'how do I remove menu & certain extras and only keep what I want?'
I may as well mention that DVDShrink actually does NOT allow you to remove titles. In reauthor mode it allows you to ADD titles including converting menu's to titles
You start off with no titles in the reauthoring window so how can you remove them?
the simple fact still remains, IC7 can remove selective titles from a DVD (albeit a hack and when they are not linked) whereas DVDShrink can't. If anyone thought I was talking about removing titles from a menu free DVD then I'm sorry you were misled by my post
why is title removal one of the most wanted features for DVDShrink if it's already possible?
cheers -
"Don't the vast majority of DVD's have menus?"
I would guess yes.
"Therefore wouldn't removing titles from a DVD would leave menu's."
It would unless you remove the menus too. But that's really not revelant to this discussion. You can remove whatever you want.
"I think you already know this but this is just in case you don't. If people want to strip menu's from a DVD then they normally ask 'how do I make a movie-only?'"
I don't know that people would "normally ask that. I see a lot of posts here with questions that don't use what many people would consider the normal terms.
" may as well mention that DVDShrink actually does NOT allow you to remove titles. In reauthor mode it allows you to ADD titles including converting menu's to titles You start off with no titles in the reauthoring window so how can you remove them?"
If you start with 5 titles and use the reauthor mode to add 2 titles to a new disk, the resulting disk will have only 2 of 5 titles. You can play word games with the process, but the end result is that you've removed 3 of the 5 titles. But you can remove titles- go to the reauthor window and drag everything to that window. Then right click on the things you don't want and delete (remove) them.
"the simple fact still remains, IC7 can remove selective titles from a DVD (albeit a hack and when they are not linked) whereas DVDShrink can't. If anyone thought I was talking about removing titles from a menu free DVD then I'm sorry you were misled by my post"
I read it as removing titles without regard to menus.
"why is title removal one of the most wanted features for DVDShrink if it's already possible?"
Because if you use only DVDShrink and remove a title then you have a dead link on the menu. -
it's more than relevant, show me how to remove the menu's with IC7. When someone talks about removing titles most here will assume they want to keep the DVD as it originally was and not reauthor it. I cannot believe you actually wish to discuss this and try and twist the obvious to show me as the fool, but I'm quite happy to continueOriginally Posted by BobK
and what would you consider normal? How would you ask? Here's one of many types of posts I normally see HERE, HERE and HEREOriginally Posted by BobK
a simple question on the DVDShrink forum HERE says it all as the man himself ddlooping knows more about DVDShrink than most and I dont see him saying you can do it
You still dont get it do you? When you START reauthoring in Shrink there are no titles! You yourself have just said it, you are saying to ADD them and then you say you are REMOVING them in the end result. You have never removed them in your actions. You can also add as many titles as you want so you could if neccessary end up with more titles in the final result
Then you read it and misunderstood just as Noki did, and what is unbelievable is that you still do not understand after reading even more?!?!?. Why not just admit that and be done with?Originally Posted by BobK
. I have always thought you know your stuff BobK but I have my doubts now
roflmao, BobK either you are taking the piss now or you just don't have a clue. Which is it?. How can you remove a dead link on the menu?. When you keep a menu in reauthor mode the ALL links are automatically removed as it then acts like a titleOriginally Posted by BobK
I suggest you go and fully play with the Reauthor feature before posting again to argue your points. You are begininng to look stupid either on purpose or by your lack of knowledge. If I was to state all I stated so far in every post I ever make here there so that everyone would understand right down to a complete newbie level, then my original post would be as long as this thread!
Why not just admit that you cannot selectively (as in click a box, button whatever) remove titles with DVDShrink but you can with IC7. You can twist it whichever way you want but the fact remains, it is impossible to remove titles in DVDShrink and get a similar working DVD minus the titles. The best thing you can do is choose Still pictures
if you can admit this is the fact then this thread can get back on topic as it is drifting due to your lack of understanding of how DVDShrink currently works
just in case you are still confused let's look at what I said
Now that mean's DVDShrink cannot reproduce the same results as IC7 when it comes to removing titles. Nowhere did I mention removing menu's (which you agree are on the majority of DVD's) and it's common knowlegde again that IC7 alone will not allow you to remove menu's. Now seeing as I'm talking about a hack that is also used by most then it can be classed as an option though not officially supported. IC8 actually supports this now but that's not the issue. Show me the option in DVDShrink that allows me to get exactly the same working results when removing (adding then removing) titles in reauthor mode each and every time as you can in IC7. I cannot think of many example DVD's can you?Originally Posted by MackemX
just in case others decide to jump in without first looking please don't get me wrong as I know and have used methods to remove titles using DVDShrink. It involves the use of 3rd party tools and a little bit of knowledge whereas IC7 only requires the simple hack which I stated many many words ago
wow, my posts are really getting long to explain my inital points. I wonder what it is and this is the exact reason I don't because will anyone read all this crap above just to understand DVDShrink does not remove titles in the way this request is most commonly referred to?
cheers -
mackemx I understood the meaning of your post similarly to bobk, that makes three people at least who misunderstood your initial post, so maybe you didnt explain yourself clearly.
Move up to InstantCopy 8 (many small bug fixes) at $35 it is just about 'free' and produces video quality superior to all the others. I've even set the destination size down to 4400. No need to worry about stripping out a few extra MB's, or filling the disc to the brim, just let it squeeze. None of the other software suggestions can match the quality. It's a little slower, but whatever it's doing, it does it well.Originally Posted by chsrao
MackemX
regarding your berating of BobK...totally childish and uncalled for.
Great minds discuss IDEAS
Small minds discuss PEOPLE
you have to be kiddingOriginally Posted by RabidDog
seeing as it is a known fact DVDShrink does not remove titles from a DVD its a very valid statement that you have simply misunderstood. It's not misleading at all. I am comparing IC7's title removal feature to the lack of DVDShtinks. If you wanna disagree and claim it does remove titles then fine. Even if it 'removes' titles it doesn't doing it without removing the functionality of the menus and that I wouldn't class as removing titles in the same way as IC7 does
anyone with a little knowledge of both IC7 and DVDShrink cannot say that DVDShrink can remove titles as IC7 can
I could spend all day on this forum saying I do not know what you mean as your statement is misleading. Why bother if what is stated is true but due to my lack of knowledge it's misleading
try telling that to the guys who really deserve it and see what response you getOriginally Posted by noki
. I see a lot worse than that on this and other forums yet I don't see you posting your opinions of people's actions there
, so why pull me up on something as trivial as this thread?
a previous post by you I just recalled HERE, as you didn't know DVDShrink is a decrypter, which may explain your misinterpretation of the above post or you were taking the piss outta Slumpey as you thought it wasn't a decrypter
. I would assume you know your stuff seeing as you post about DVDShrink quite a lot. Maybe you know a little more now
anyway who cares, maybe I've got two minds
, and if BobK feels critized in any way I apologise as I also assume he knows the basics as I have also read a few of his posts in my travels and don't class him as a newbie to the game
I'm just an ASSumer
I do hope you understand my intial post now and note how we were not splitting hairs
EDIT
I've just noticed BobK's initial post, so ain't we all the same
x264.exe error in mequi
By Banaanas in forum Video ConversionReplies: 6Last Post: 31st Jan 2010, 15:41 -
lsass.exe error
By jjis in forum ComputerReplies: 2Last Post: 28th Nov 2009, 22:32 -
x264.exe error
By streetak in forum Blu-ray RippingReplies: 1Last Post: 1st Feb 2009, 13:17 -
error with spumux.exe
By rebel14 in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2008, 19:55 -
Xvid Encraw.exe error
By theninger in forum Video ConversionReplies: 3Last Post: 2nd Dec 2008, 19:27
