Hi Folks,
I am experiencing a .DV to mpeg2 conversion problem and am hoping someone can shed some light onto the issue.
I am using formac's studio tvr to capture video. When I convert it to a m2v file then play it with quick time it freezes on a frame after 20 minutes or so.
The complete m2v file appear to all be there considering that it is 4.5 gig big..but like I said it hangs up.
Currrently I have about 22 gigs of hard drive and am converting a 30 gig movie to an appr 4.5 gig m2v file.
I have selected "DVD (NTSC) Normal" for video encoding
the aspect ratio selected is 4:3 (PAL/NTSC)
Video= NTSC
Bit rate = 5.4 Mbps
Size = 720 X 480
and the encoding speed is medium quality.
Any thoughts?
Crayfish
Hi, I cant answer you question but I use the same hardware to capture .dv content too. How do you view the m2v? I have QT Pro 6 and I cant view an m2v . . . Thanks
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 01:05 -
batch conversion of bmp to m2v files?
By ecc in forum Authoring (DVD)Replies: 3Last Post: 29th Feb 2008, 08:37 -
M2V To Avi Conversion Issue
By R3bel in forum Video ConversionReplies: 2Last Post: 4th Sep 2007, 20:15
