Hello
I have a Dynalink BT878 based capture card which has just been transfered to my new shiney PC. In my old PC capturing above 320x240 wasn't possible due to dropped frames. Now frames are OK but video quality is very bad!! Usually associated with motion, thin black horizontal lines cover the screen but only while capturing.
I have used most of the video capture programmes listed in this site and tried 3rd party BT chip drivers as well without luck.
I have been told it may be a PCI latency problem and to try to swap the card thru the available slots. Didn't work.
Has anyone got any suggestions?? or even proof that this level of card is even capable of 704x576 capture.
How old is the card? May be too old and time for an upgrade.
Card was bought in 99.
Is there any different variations on the bt878 chip??.
I thought there were several trillion of them out there just like (or similar) to mine.
I guess I'm working on the theory it should be possible with my hardware unless something isn't setup right.
cheers -
Mate,
Just a guess, I think that's what's called interlacing. Only analog capturing give interlacing. Digital display are progressive. You may need to look into interlacing a bit further.
Cheers,
feeras
Looking For High Res Animation Advice
By David Bethel in forum Newbie / General discussionsReplies: 119Last Post: 8th Mar 2010, 12:09 -
Converting High res JPG File into HD Slide show/HD Movie
By dominic01 in forum Video ConversionReplies: 4Last Post: 13th Oct 2009, 02:58 -
How to add high-res album cover art to your mp3 collection
By timmy2 in forum Media Center PC / MediaCentersReplies: 0Last Post: 3rd Mar 2008, 00:20 -
Advice on High Res Video Capture Hardware
By Gregus in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2007, 15:54 -
High Res Presentation video (Frapsed)
By Flawe in forum Video ConversionReplies: 1Last Post: 28th May 2007, 07:01
