Im tryin to look for good reliable media for Pioneer A06 i just bought (Best Quality/Price ratio). Looking for 4x DVD-R. Also id like it to play in my panasonic rv30 standalone. May also be Printing DVDS if someone can point me to a good place to get a good dvd printer.
Thx in advance
Results 1 to 15 of 15
i have pioneer 106 and use datawrite yellow 4speed disk and there great for movie or console game back ups,infact i`ve had better results with these than with the ritek disks that everyone ravesabout
good luck and happy burning -
I have a Panasonic RV31 player (almost exactly the same as yours). I have had no problems at all with Fuji (TYG01) and TDK (RITEKG04). Both of these are 4X DVD-R's. I have also had no problems at all using DVD+RW's in my RV31. I have tried Fuji (RICOHJPNW01) 2.4X and Verbatim (MCC A01) 2.4X.
I had tons of problems with the other DVD-R's I bought which were also TDK but had a media code of MXLRG01. Every single one of them burned fine but if I scan the disc using Nero or DVDInfoPro they all have errors.
I know you can buy RITEKG04's that are inkjet printable. They come highly recommending according to most of my reading here.
-Darryl -
hello im new to the forums and i was gonna ask same question i just got my Pionner A06 and wanted to know wat are the best dvd-r. I tried memorex dvd-r 4x there are horrible for movies. can anyone point good website were to get the those TDK (RITEKG04) which are suppost to be good
tx -
RITEK, RICOHJPN, MCC, MXL, PVC
One of the best discs in my opinon and from what I've read is the Ritek G04. TDK is using them now too and putting their name on it. If you don't want to spend the money on a 4x disc (I wouldn't record a movie in 4x and most people wouldn't either), I would recommend getting the Ritek G03 disc. The A06 burns it a 2x speed and it seems to be the media of choice right now. I remember a month or two ago the demand was so high that the price of this media doubled! It can be had for around $85 delivered. Check out rima.com, supermediastore.com or mertiline.com Good luck
Something to do with the integrity of the movie. Some people belive that a slower burn will cause lesser problems and skipping etc. They said the same thing with music cds at 12x speed. Now everyone's burning at 52x speed. I guess better media?
If the discs are 4x, & they are decent quality discs, (like ritek GO4 or Taiyo Yuden) then burning movies at 4x shouldn't hinder your results in the slightest,
(Unless your burner has been kaned hard & is on it's way out!)
Also, the latest burners on the market are way better then they were 2 to 3 yrs ago, in general they will burn for longer before developing problems. -
RITEKG04
If there are probs with the discs in players it comes down to the way how the disc is burnt. Some players are picky, some aren't.
The most compatible discs in my experience are made by doing an image with ImgTools classic and then burn them with whatever burning software you like. I use DVDDecrypter. -
I agree, converting to image file is the way to goOriginally Posted by Coopervid
Probably you want to try Prodisc 2X DVD-R from supermediastore.com. The Prodisc discs are Pioneer Certified.
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58 -
Does Pioneer DVR-112D burn DVD+R and DVD+R DL media well?
By palmtree in forum DVD & Blu-ray WritersReplies: 26Last Post: 4th Jan 2008, 04:22 -
What is the best DL media for Pioneer 1810 and DVR-710 drives ?
By MacPCConsultants in forum MediaReplies: 9Last Post: 2nd Dec 2007, 14:37
