I had ripped a lot of movies, some of them have RCE protection like (Indiana Jones,
The Simpsons 3th Season and others)
I fixed them with IFOEDIT in order to make them work in my harddisk before burn them.
I have a problem with other movies like Sleeprs or Reign of Fire. After
ripping these ones, IFOEDIT does not detect any RCE protection and it works
fine in the computer.
After burn, the copy doesn't work in my Panasonic AK31 (region 1) and other
old standalone players.
In order to make a full region free copy for all standalone players I would
like to know:
How to set a region to IFOEDIT 0.95(in playback) or other software like
PowerDVD ver.4
I could be wrong but I think software region is set to whatever your hardware region setting is. There are programs out there to bypass that and modify powerdvd for instance, etc.
Anyway you can check RCE protection with dvddecrypter and another free tool. See here http://mrbass.org/dvdrip -
Welcome to the forums, FrankRM.
You could try using DVD Shrink v3.0 beta 5 to remove RCE.
Set it to "No compression" if you want to use another software to compress if and when compression is required.
CD protection!
By Browncoat in forum ComputerReplies: 3Last Post: 17th Mar 2011, 05:11 -
RCE Protection Issue
By tryst1 in forum Authoring (DVD)Replies: 1Last Post: 24th Jan 2010, 09:53 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 22:39 -
RCE protection removal..............
By efiste2 in forum DVD RippingReplies: 12Last Post: 21st Jul 2007, 12:42
