I have just bought an ACER 244LM with a Matshita DVD-RAM UJ-811.
I have tried burning a dvd-rw but had no success using Nero 6 and Recordnow.
I'm a bit confused.
I wanted a dvd-r drive and the product spec for this machine states a DVD-RW drive. Can this DVD-Ram drive do the same things as a dvd-r?
I wanted to be bale to backup ps2 games as well as video's.
Have i got the wrong type of drive or is it just a media problem. I am using a Jessops own brand DVD-RW disc.
Any help or info would be gratefully received.
Thanks.
Well thanks for all the help guys!
I'm posting this for reference for anyone else who is a stuck with the same problem.
I solved my own problem by trying a better brand of media. Memorex DVD-R seems to work just fine, so i guess it was a media issue.
Hey,
I have the same model notebook and I find mine can't regonginse some DVD+Rs I bought, it says i need a firmware patch to update it but my burner make isn't on the site, does anyone know where I can get one from? -
If you have the same model notebook as me thern your dvd only supports dvd-r. It should only read dvd+r - but it won't write to it.
Ahh thanks, will DVD-R play on new DVD players though? Please excuse my ignorance but am not entirely familiar wil the DVD types
I have a Gateway PC with the same DVD/ RAM drive. It cannot write nor read RW DVDs though it can read and write to -Rs but not +Rs, That's why I bought and external DVD-+RW 4x Drive which I use. The Ram drive only burns at 1x and it is very stable. It will read some of my DVDs that the other drive may show read errors due to disk scratches. The Matshita will for some reason read them perfectly well and so I use it mostly for all ripping sessions and backing up with DVD Shrink.
No DVD can withstand the power of DVDShrink along with AnyDVD!
Help desperately needed with HDD problem
By jeanpave in forum ComputerReplies: 28Last Post: 17th Jul 2011, 23:41 -
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 12:50 -
DVD Ram Drive
By gemma-the-husky in forum DVD RippingReplies: 5Last Post: 26th May 2008, 19:49 -
Help with Matshita Drive/Adobe Encore V2
By bailout in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Aug 2007, 14:16 -
matshita dvd ram uj 840s
By skaterboii in forum DVD RippingReplies: 3Last Post: 16th Jul 2007, 05:11
