I live in the USA, so everything I do is in NTSC. My brother, however, lives in Malaysia which is a PAL format country. I was going to send him a DVD of my kids, but I'm not sure if I should author in PAL or NTSC.
In many other posts, the concensis is that most European players will play both PAL and NTSC, so would that also apply to Malayasia?
My concern is that I can't test a PAL DVD to make sure it works, and if he can play my NTSC DVD in a PAL country, then I would rather send him a disc that I know works correctly.
Any thoughts?
Generally speaking most DVD players will read PAL or NTSC (even US ones), but most will not convert the signal on the fly for you. So you still need a NTSC or PAL TV to view the picture.
You should call and ask your brother, but my quess is that if you give him a NTSC DVDR he'll have no trouble playing it. On the other hand, if you've captured home movies following the NTSC standard, and they try to convert/author them as PAL... that's asking for a LOT of headache/problems. -
Yep agree with Vejita-sama
practically everything in Asis ( and this extends to here in Australia) is multi-format
In fact you have to look really really hard to find a single format only DVD player or TV
I don't think he will have any problems playing whatever you send him
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 14:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56
