I've ALMOST successfully authored all of my mpegs to DVD but I'm having a small problem in TMPGEnc DVD Author. When I play the DVD that I've created, the menu which shows all of the tracks displays for a split second, and then vanishes and the first track starts to play. Has anyone else run into this problem? Anyone know how to fix this?
Hmm, that's strange because the main menu usually doesn't do anything but sit there until you press play. Check your "First Play" options in TMPGEnc DVD Author.
I always test my DVD using PowerDVD before I burn it just to make sure everything is working right."Can You Dig It!" -
When you are at the create menu's stage look to the right, it's just under options.
Sticking subtitles in mp4 videos
By kaz219 in forum SubtitleReplies: 4Last Post: 19th Jan 2010, 20:19 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
Tevion 8001 HDMI DVD player - disc sticking/freezing problems.
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:50 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
