i have a film here in 2 cue/bin files.
what i want to do is convert the 2 bin files to mpeg then join them together and burn them onto dvd as on disk.
i used iso buster to convert the first bin file and it saved it as AVSEQ01.MPG but then i tryed to convert the 2nd bin file it said "the selected file already exists do i want to overwrite".
because it makes the file as AVSEQ01.MPG also.
so i thought i will just add 02 instead of the 01 that is there,so that converted ok.
so i normally use tmpeg to merge the mpegs but this time i added the 2 mpeg files and it told me that AVSEQ02.MPG is not compatable with the AVSEQ01.MPG.
what am i doing wrong?
hope i dident confuse everyone !
