Hi, all
I'm a newbie and I've read about converting from DVD to VCD using Sefy's Guide.
I'm at the step where you use TMPGEnc.
Is it OK if I do something else (surf web and looking at Email) while its converting from DVD to VCD?
Will it affect the picture or sound quality?
OR should I leave my PC alone for 6 hours?
My system is:
PIII 1Ghz (100Mhz FSB)
Abit BF6 (BX-chipset)
384MB SDRAM PC133
Windows 2000 Pro
Thanks in advance.
<font size=-1>[ This Message was edited by: stmok on 2001-07-09 20:33:59 ]</font>
I think the only problem you'll run into, from my experience, is that it takes longer.
Blueray to WMV-HD with 5.1 or Stereo Quick Guide
By DexterF in forum Blu-ray RippingReplies: 1Last Post: 18th Dec 2008, 18:51 -
TMPGEnc 3 - Quick Menu Question
By heyjjjaded in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2008, 14:05 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 16:04 -
TMPGEnc DVD Author - Quick Slideshow Question
By heyjjjaded in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2008, 06:13 -
Sefy's Guide and Correct Setting for DVD (NTSC).mcf
By moviebuff2 in forum Newbie / General discussionsReplies: 8Last Post: 1st Aug 2007, 09:01
