Some VCDs contain AVSEQXX in the "MPEGAV" folder while some contain MUSICXX (which I hear is created using EASY CD Creator) in the "MPEGAV" folder on a VCD. What is the technical difference between the two? As I had problem of "Windows Media Player" not recognizing the "MUSICXX.DAT" the on Win98SE earlier (now I hardly ever use WMP on my Win2K Pro system).
Does ripping and conversion of these kind of files differ from the "AVSEQs", when u are converting from a VCD to a SVCD? Do these files have a different CD-i Bumper or Header than the AVSEQs?
Results 1 to 1 of 1
regards
Amey
MPEG-4 ~ what's the difference?
By kr236rk in forum Video Streaming DownloadingReplies: 15Last Post: 3rd Feb 2016, 09:31 -
is it possible to feel the difference?
By FaisalKhan in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2011, 06:17 -
Difference matte?
By Abiyad in forum MacReplies: 3Last Post: 22nd May 2008, 16:38 -
what is difference to + and - DVD-R and RW?
By snadge in forum DVD RippingReplies: 2Last Post: 27th Feb 2008, 13:14 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 13:59
