Hi all
trying to encode DVD from XviD using avisynth and if I want to add
.avs script in CCE i got error : "NewMovieFromFile() failed (0)."
Any help? Tnx for reading.
F.
no, even other vfs (with other avi) doesnt work with CCE
maybe i have wrong version of CCE
(Cinemacraft.Encoder.SP.v2.64.01.02) will try another -
Yes, only 2.66 and newer will work.And don't forget to demux before and remux after encoding.CCE will do strange things to audio.Good luck.
As CCE is not the best at dealing with Audio, you should encode the Audio stream to mp2 or ac3 with a different tool (BeSweet or HeadAC3he).To do this, you nbeed to separate the streams and let CCE just convert the Video stream).After processing both streams, you must remux (join together) the streams (this can be done by some DVD authoring tools like IfoEdit).For ULEAD MF you need to mex them with tmpgenc (mpgtools).
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 04:24 -
CCE, AviSynth and MP4 Question
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 31st Mar 2008, 11:19 -
MKV, CCE and AviSynth Question
By Maikeru-sama in forum Video ConversionReplies: 10Last Post: 14th Jan 2008, 16:35 -
Matted to anamorphic with aviSynth/CCE?
By Sephiroth666 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2008, 00:00 -
Questions about CCE, H264 and AviSynth
By Maikeru-sama in forum Video ConversionReplies: 18Last Post: 21st Dec 2007, 20:38
