I have several movies in VHS that I wish to transfer into DVD format (i.e. Wedding Day). The only way I can get it to work is by first dubbing the VHS tape into a DV tape and then capturing it off the DV tape. However, I wish to do it without having to transfer it to a DV tape first.
Setup: VHS ---RCA---> Elura20MC ---Firewire---> PC (port on Audigy)
If I start to hook up the cables at the VHS, everything seems to work until I plug in the firewire at the PC. It seems that the Elura20MC is expecting an input from my PC. (Mind you there are no applications running on the PC, just WinXP.) If anyone out there has a solution to this,
Thanks in advance,
Kervin![]()
After checking Canondv.com, it dosen't appear that you can capture video going through the camera to the computer without first capturing to DV tape.
My Canon ZR cam does it but you have to not have a tape in the camera.
And not all NLE's will capture this way. (At least for me) I use scenalyzier live for capturing.
I'd double check the manual for your camera about the pass-thru thing.
Selecting passthru audio in MPC HC rather than the prologic
By skinney6 in forum AudioReplies: 2Last Post: 26th Jan 2012, 12:37 -
Canon HV40 analog/digital pass through?
By stantheman1976 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 30th Jun 2011, 07:23 -
Difference between Canon Vixia HF-20 vs Canon HF-S20?
By Wink in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Nov 2010, 17:46 -
Canon Rebel xti + Canon HV30 vs. Canon Rebel T2i
By assman24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Jun 2010, 12:47 -
can't figure out passthru with JVC GR-DVL820U
By MajorMalfunkshun in forum Capturing and VCRReplies: 1Last Post: 3rd Jul 2009, 01:50
