hi there. i received multiple errors from nero 5.5 when burning data to a well-known brand DVD+RW. the errors go from 'unable to access drive' to 'file-error (40)'. i wondered if there's anyone using the same drive under Windows 98 too, and what program they use. thanks.
As I recall, Nero 5.5 doesn't recognize an NEC1300a. It's too new. It may be treating it as a different NEC drive.
Have you tried burning with a different app, like DVDDecryptor?
Do you have 4.71 ASPI drivers installed (this is a general driver, not 98 or NEC related)?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
the version i'm using does. it's above 5.5.10. i already got this working, thing i gotta do is reboot without anything else starting up and then burn a dvd. thanks for the help anyways.
Smells like a memory issue. 98 doesn't have a decent memory manager. Burning DVD's isn't neccesarily RAM intensive, but it does use a chunk for cache. You need to fill out your profile to help troubleshoot hardware issues.
!!Please help me!! Windows 7: Windows Update in not working
By flashandpan007 in forum ComputerReplies: 3Last Post: 23rd May 2011, 20:14 -
Windows Media Center .wtv 720p (60fps) to Xvid AVI (24fps) in Windows 7
By cg-realms in forum Video ConversionReplies: 0Last Post: 7th Jan 2010, 18:47 -
Windows 2003 or Windows 2008 based on my server specs & needs...
By retroborg in forum ComputerReplies: 18Last Post: 23rd Jun 2009, 06:29 -
How similar is Windows Server 2008 to Windows Vista?
By davidsama in forum ComputerReplies: 6Last Post: 12th Nov 2007, 10:25 -
windows mp is not playing sound on videos (but only on one windows account)
By lightsout85 in forum Software PlayingReplies: 0Last Post: 30th Jul 2007, 15:19
