http://www.ezbsystems.com/ultraiso/history.htm
Revision History
17, UltraISO 6.52 (November 16, 2003)
+) Supports ISO image with RockRidge extension (Linux/Unix CDs)
+) Option to omit ISO 9660 version number
+) Advanced Options such as 'Super Restore' and 'Add Joliet Volume as needed' can be changed
+) Can refresh local directory files
*) Improved SPTI interface
*) Fixed 'Disc Locked' problem for some CD/DVD-ROM devices
*) Some minor bugs fixed
Main Features
Can directly edit the ISO image file.
Can directly extract files and folders from ISO image file
Can add / delete /create new directory /rename ISO file image content.
Can make ISO file from hard disk document.
Can create CD image from CD-ROM, maintain bootable information.
Can process the compact disc boot information, you can directly add/remove/extract boot image of the ISO image.
Supports nearly all known CD image file formats (.ISO, .BIN, .IMG, .CIF, .NRG, .BWI and so on) , and converts them to the standard ISO form image.
May directly set the file/folder to hidden attribute
Supports ISO 9660 Level1/2/3 and Joliet extension
Automatically optimizes the ISO image file structure, saves the CD space.
Supports the shell document type integration, Open Image files through double clicking them or the Right Click menu of the mouse with the open dialog.
The double window user interface is extremely convenient to use.
There are rich add-on tools, you can create ALL in 1 bootable compact discs, CD image file management, even the virtual CD/DVD drive , those functions are really powerful.
Results 1 to 1 of 1
UltraISO Question
By m02499 in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2010, 00:12
