  1. I had bought a Panasonic E60, it support dvd-ram / dvd-r,
    dvd player can play dvd-ram in left or right channel,
    but dvd-r only can play both channel in same time, which left is chinese, right is english,can't choose L/R.
    I capture dvd-ram to computer by using Ulead DVD factory 2, and it capture mpg file are in both channel, can't choose L/R
    My question are :
    How can i convert the mpg file to have L/R channel??
    thx all
  2. demux your sound track capture the left only as track1 and right only as track2 then re-mux with video as 2 seperate mono tracks.
    The electronic components of the power part adopted a lot of Rubycons.
  3. Ok thx,
    Which demux software do i use??
  4. If the file is a VOB use VOBEDIT->Demux,if the file is MPEG then use TMPGEnc->MPEG Tools->Simple Demultiplex.Then you will have to convert to WAV, then you will have to use Audacity to split channels and create a mono file,then convert to MP2 and finally multiplex with TMPGEnc.
    I would recapture the film but use a RCA(composite) to mono plug.
  5. Thanks
    I had tried, and it is work
    but sometime i use VOBedit can demux to wav file, but sometime only can demux to ac3 files.
    May u give me some guide??
