FFMPEGX (sound out of synch, low quality); Demux, re-encode audio, remux, convert, but ended up with serious synch problems (again!!), I even tried just dumping the file into Toast 6 (Mac OS Error). Of course I tried QT Mutator and in quicktime it synched OK, but the final VCD was out of synch. These files play beautifully in VLC. Help!!
mpeg2works? does it have problems?
quicktime (after doctoring it) and exporting to video cd does it have problems?
if its a downloaded divx movie you have to understand that there could be some inherent problem with the file itself.
VLC is way to forgiving of a media player to say well jeeze it plays in vlc so it must have no problems. -
What about :
Process through DIVA,get intact video file.
Extract audio only through ffmpeg using .mp3 settings
use QT Pro to add scaled video to audio and save file as
Toast compatible mpeg?
I've done before on [crap] MPEG files from Usenet...
this procedure works good.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 20:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
DVD to DivX w/ AC3
By MoVieBoy007 in forum DVD RippingReplies: 12Last Post: 26th Apr 2008, 23:03 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
