Im looking for a good authoring tool that has flexible menus, makes slideshows with multiple audio, Audio fade in/out for slideshows, can burn VCD/DVD and supports AC3. Conversion is not needed since I will be importing compliant video.
Currently Im using Moviefactory2 which is great but it can't accept multiple audio and no fade in/out for the slideshows. Also there latest update has prevented the AC3 cheat. Most of my Authored DVD's include a few videos and a few slideshows. The lack of audio control in the slideshows is starting to bother me when the music just abruptly stops at the slideshow end.
I know that there are some big $$$ tools around to do this but Im interested in some simple cheaper ones. I already checked the "Tools" section but its difficult to determine the slideshow capabilities.
I have the Sonic MyDVD version 4.02, it came with my DVD drive. Version 4 seems to have a few problems and it doesn't support AC3. I saw on the Sonic website that ver5 deluxe supports AC3. Does version 5 run much better?
MachineMan, if your DVD-RW drive is a Sony, you can upgrade MyDVD to 5.2 LE free. Just go the Sony support site.
5.2 does give you the option to do AC3 but only in 2.0. I am still using the 4.X, but have 5.2 in another drive for the same PC, mainly for 5.2's better sound quality in capturing DV.
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
authoring tool for HD video -> DVD
By feh in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2009, 14:03 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 15:37 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 09:21 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 13:45
