I just noticed that supermediastore.com has Ritek 4x double sided -R that you can record on both sides for sale. I have never seen those before. Has anyone ever used those?
They work fine, but the question for most people is why would you want to ?
Unless you have one of those rare beasts than clan play both sides of the disc without you having to get up and turn it over, you still have to flip the disc, in which case you might as well use 2 DVD-R's which will no doubt cost you less than one double sided effort...
One sided right bar in Virtualdub ...
By holeepassion in forum Newbie / General discussionsReplies: 13Last Post: 22nd Apr 2012, 15:16 -
How can I join two sided dvds.......................?
By forest.lawn in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2011, 19:51 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Double sided discs
By brainoverload in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 11:15 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
