I have some DV AVI footage from a live show. It contains some fast movement shots of the drummer and there's strobe lighting.
The show is approximately 90 mins long and I plan to record this to a DVDR. I want to retain the FULL quality of the original footage so my questions are:
In Canopus Procoder...
1. What bitrate should I encode to? I don't mind using two discs if necessary.
2 Is VBR the same as mp3 vbr encoding ie: you are not wasting
space on sections of the recording which do not require a high bit rate ( slow quiet sections for example) is CBR not wasting space?
3. I did a test using 7000 cbr master quality. It looked great, but when I checked the bitrate using my standalone dvd player, it reported bitrates of 8-9.5. How come? when I encoded this at 7000.
enlightenment please thanks![]()
I don't use ProCoder but your question are pretty generic and not really specific to procoder so I shall try and help.
Really only you can answer this as only you know what quality level is acceptable. Higher bitrate = higher quality (in general).Originally Posted by bode
You have the right idea there.Originally Posted by bode
Not usre, maybe your DVD player reports the MAX bitrate that is in the mpeg header, or maybe you made a mistake when setting up procoder. Use Bitrate viewer to check the real bitrate of the mpeg.Originally Posted by bode
From your description of the the video (fast movement, strobe lighting etc) you will need a high bitrate for these scenes. VBR is probably your best bet with the max set to 9 or even 9.5Mbps, min 2mbps and average about 5mbps. Encode that and check the quality. If its not good enough in the low motion scenes, increase the bitrate and split to two disks. WIth those figures though, you can't go much higher for the MAX bitrate so the high motion scenes won't get much better.
FYI, the MAX bitrate allowed for DVD video is 9.8Mps. The MAX total bitrate is 10.08, so using the max bitrate for video leaves little room for audio. Even at 9.5Mps max video you will need to use 2chan Ac3 or mp2 audio.
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 23:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 00:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 22:03
