Ok guys. I need some help. I am using virtual dub and I am trying to attach 2 avi files. It says that I have a vbr audio stream so the audio might be out of sync. So I run mp3 freeze and it says there are no bad frames. And I also run virtual dub checking for bad frames and says are none but undecodable. Is there a way to reencode the avi's and save them as avi's so they both have the same audio rate. I also remember when I tried to attach them together there was something about the 2 audio rates being different. I use tmpgenc as encoder. Can I reencode them and same them as avi's or what can I do. I am perplexed. Thanks for the help.
Jim
Run both files thru virtualdub as direct stream for video and full processing for audio and save as,then join,check for audio sync after for any errors.
Thanks John. I will give it a try and let you know. Thanks again.
Jim
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 06:00 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 06:00
