I just copied a vcd karaoke disc to a regular cdr using a adaptec software and a smart and friendly CDRW 226 burner it went fine I tested it with my player in the pc it works but when I put it on my dvd player, that reads VCD also, it loads but freezes and Im using a samsung dvd m301 need your help and could you suggest 2 different softwares Im so close thanks a lot
maybe your player doesnt support CD-R media.
if that is the problem I dont think you can deal with it.
Try the Burned VCD on another FRIENDS dvd player and see if it works.
Cheers!
F1!! F1!! F1!!! -
thanks for the advise but according to the manual of my player it reads cdr and cdrw it reads my audio but I will still try it with somebody elses player . If you have other suggestion please tell me worst comes to worst I could always change my player
i am also trying to burn a karaoke vcd...can you please help me out about what i need. i cant seem to get past the copyrights.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 04:50 -
how to copy the contents from a scratched vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 36Last Post: 28th Dec 2007, 02:03 -
copy contents from vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Dec 2007, 00:34 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20
