Ok here my problem..... I tested out tha svcd2dvd demo & really liked tha results being that i used other programs that took damn near 10 hours juss to encode a mpeg into a AUDIO_TS & VIDEO_TS folders......well svcd2dvd took roughly an hour.....tha problem i had with tha demo was that after i burned tha _TS folders to a dvd-r none of tha chapters worked.....tha picture & sound came out juss fine but i couldnt get tha chapters to work....ok......so then i said i really like this program so ITS A MUST i make a donation & get tha fully registered version.....so after i got tha fully registered version i tryed runnin tha program & now i get empty _TS folders.....i knew it was to good to be true cause like i said tha demo was takin about a hour while this version was taking around a half hour.......so i uninstalled tha full version, reinstalled & tryed agin with tha same results.....empty _TS folders.....so i tryed tha demo version & it worked but again....no chapters were working......im kinda upset bein that i donated & it seems like tha free version is working better then tha version i donated for but hopefully someone can help me......i will attach pictures of both tha demo version & fully featured version
Results 1 to 15 of 15
well im trying 2 attach pics but it wont let me .....it has a url n it & i dont wanna break no rules so if u say its coo 2 post them then lemme know
teedow: The problem is not the version of SVCD2DVD but the source mpgs. You get chapters with the FULL version, not the demo - correct. The demo is around 30% slower also. So to get to the bottom of your problem I need to see your log file. Can you either email it, link to it or post it here?
I hope these links work for u & thank you soo much for ur help.....tha first pic is my log from tha demo version & tha second pic is tha fully registered version
^^^ If those aint tha logs u need then i think i know which ones ur talkin bout.....thx soooo much for tha help tho homie
If you update your FULL version then you can view the log as follows:
When the process is finished just upload it here.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
aaight, well now when i run my registered version it wont even create my _TS folders....its stop at " Multiplexing elementry streams " & when i ran tha demo version everythang went good....heres tha logs...first is my registered version & next is tha demo version
Registered Log
Starting SVCD2DVD: v1.5.1417.23038
Begin time: 3:02:21 PM
******** Ripping SVCD images to get mpegs
++ WARN: found (non-compliant) SVCD ENTRIES.SVD signature
(Total size: 1095MB, Duration: 00:05:03, Rate(MB/Min): 216.82)
Analysing File: C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01.mpg
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Error getting mpeg details. (probably due to AC-3 audio)
System.Xml.XmlException: An error occurred while parsing EntityName. Line 1, position 51.
at System.Xml.XmlScanner.ScanNamedEntity()
at System.Xml.XmlTextReader.ExpandLiteral(XmlAttribut eTokenInfo currToken)
at System.Xml.XmlTextReader.SetLiteralValues(XmlAttri buteTokenInfo fld)
at System.Xml.XmlTextReader.SetAttributeValues()
at System.Xml.XmlTextReader.ParseElement()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at _S_VCD2DVDMPG.frmMain.UpdateMpegDetails(j mpeg)
-->Processing 1 mpeg files.
############### New MPEG File ###############
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
(Total size: 543MB, Duration: 00:07:14, Rate(MB/Min): 75.04)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 42MB, Duration: 00:01:56, Rate(MB/Min): 21.63)
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] Unable to open file C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpv for reading.
System.IO.FileNotFoundException: Could not find file "C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpg".
File name: "C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpg"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileInfo.get_Length()
at _S_VCD2DVDMPG.frmMain.Mux(j mpeg)
at _S_VCD2DVDMPG.frmMain.ExecuteProcess()
Demo Log
Starting SVCD2DVD DEMO: v1.5.1411.27829
Begin time: 1:55:44 PM
at j.n(g A_0)
at j.n(g A_0)
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Preparing asset
Truncating Asset.
Truncating Asset - done.
Incompatible audio bitrates CD_Image_File_CD1_01_D.mpg (192 bps) C:\Program Files\Badgersoft\SVCD2DVD DEMO #2\PALVCD.mpg (224 bps)
Specified files are not compatible, if you still want to join them use --force switch
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpv...
File C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 245436
System headers = 1
Padding Stream packets = 3940, total bytes = 3709642
MPEG Audio stream 0 packets = 19336, total bytes = 44337448
Video stream 0 packets = 226099, total bytes = 513582554
Saving stream 0xC0 into file C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01-0.mp2...
Summary:
MPEG Packs = 245436
System headers = 1
INFO: [mplex] File C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 2530000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2802000
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 13019
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
INFO: [mplex] STREAM e0 completed @ frame 55377.
INFO: [mplex] STREAM c0 completed @ frame 76972.
INFO: [mplex] Multiplex completion at SCR=166261906.
INFO: [mplex] Video e0: buf= 147506 frame=055377 sector=00255281
INFO: [mplex] Audio c0: buf= 736 frame=076972 sector=00025607
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 513582554 bytes
INFO: [mplex] Sequence headers: 3953
INFO: [mplex] Sequence ends : 0
INFO: [mplex] No. Pictures : 55378
INFO: [mplex] No. Groups : 3953
INFO: [mplex] No. I Frames : 3953 avg. size 26311 bytes
INFO: [mplex] No. P Frames : 15275 avg. size 13011 bytes
INFO: [mplex] No. B Frames : 36151 avg. size 5831 bytes
INFO: [mplex] Average bit-rate : 2223200 bits/sec
INFO: [mplex] Peak bit-rate : 2370800 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 215921
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 51725860 bytes.
INFO: [mplex] Syncwords : 76974
INFO: [mplex] Frames : 76974 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
Analysing File: C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
at j.n(g A_0)
at j.n(g A_0)
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\CD_ Image_File_CD1_01_DVD.mpg...
!!!: GOP is not closed on cell boundary (may be non seamless)
-->: DVDFolders creating table of contents
scanning C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\VID EO_TS/VTS_01_0.IFO
============ Complete ============
============ Duration: 00:27:46.6875000 -
Firstly you need to get rid of the & char in the path. (shit i know but i haven't got round to sorting that)
and use bbdmux as the demuxer (set in options)
Originally Posted by ChrissyBoy
I did that and it juss stays at " multiplexing elementry streams ".......It kept running & runiing for like 2 1/2 hours until i said **** this & juss stopped it.....im lost now......i need tha demo version of this with tha option to add chapters & then ill b a happy man....this registered version is giving me headaches.....lol -
Your mpgs are:Originally Posted by teedow
which contain the & char. Can you remove/rename this.
Can you post the log og this.I did that and it juss stays at " multiplexing elementry streams ".......It kept running & runiing for like 2 1/2 hours until i said **** this & juss stopped it
Are you using the mplexwin32 in the options? If so can you try the normal mplex (this is what the demo uses).
Yes. But when we resolve the issues for you you won't look back!this registered version is giving me headachesSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
this is tha latest log that took like 2 1/2 hours that i juss stopped cause it was takin to long......when i finsih downloadin these other things ima restart my pc...make tha changes to tha directory & see whut happens then.....my question about takin out tha " & " in tha directory would b why would it work with tha demo version & not tha registered version ?? i mean im not complainin or nothin im juss curious but yah homie im willin to stick by this product till tha results come out as expected
Begin time: 5:49:33 PM
(Total size: 1095MB, Duration: 00:04:40, Rate(MB/Min): 233.87)
Analysing File: C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\cd 1_01.mpg
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
Saving stream 0xE0 into file C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\cd 1_01_DVD.mpv...
File C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\cd 1_01.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 245445
System headers = 1
Padding Stream packets = 3943, total bytes = 3714340
MPEG Audio stream 0 packets = 19344, total bytes = 44354304
Saving stream 0xC0 into file C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\cd 1_01-0.mp2...
Summary:
MPEG Packs = 245445
System headers = 1
(Total size: 543MB, Duration: 00:04:34, Rate(MB/Min): 118.54)
(Total size: 42MB, Duration: 00:01:25, Rate(MB/Min): 29.59)
INFO: [mplex] File C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\cd 1_01_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\cd 1_01_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\cd 1_01_DVD.mpv)
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Program Files\FlashFXP\Movies & Games\Snoop.Doog_Boss.Playa.SVCD.DVDRIP_H1J4CK\cd 1_01_DVD.mpa)
INFO: [mplex] Bit rate : free
INFO: [mplex] rough-guess multiplexed stream data rate : 2569144
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0! -
are you using mplexwin32 or mplex?
THX CHRIS!!! shit is working perfect now
.....but it seems i have anotha problem....its has nothin 2 do wit creating any _TS folders or anythin but my question is...whuts tha best program 2 use to burn to movies on 1 dvd-r....cause i use recordnow max & when i put two VIDEO_TS & AUDIO_TS folders to burn it only burns one.....in order to burn 2 movies on one disk do i have to do tha dvd authoring or somethin or is there a program that u have that will burn to VIDEO_TS folders to one dvd-r??
Need helping hook up stereo to HDTV?
By DM616 in forum DVB / IPTVReplies: 5Last Post: 12th Feb 2012, 22:22 -
VHS tape won't rewind in mulitple players
By robjv1 in forum RestorationReplies: 15Last Post: 19th Aug 2009, 17:18 -
Any software to convert WMV to MPEG? Thanks for helping.
By seymoria in forum Video ConversionReplies: 2Last Post: 18th Apr 2009, 09:18 -
Editing to match tapes from mulitple cameras of the same event
By SCDVD in forum EditingReplies: 5Last Post: 17th Mar 2008, 18:06 -
Helping with hooking things up..
By Superstar24 in forum Newbie / General discussionsReplies: 18Last Post: 23rd Jul 2007, 22:05
