Can any of you guys please tell me a) is it possible to b) the easiest way to change a downloaded ART picture format into a standard jpeg???
This really would be very much appreciated...many thanks kh
Originally Posted by kevinwheath
.art files are AOL compressed image files.
It isn't worth converting - the quality is awful
What you need to do, is go under key word Preferences and change your WWW settings to never compress
Make sure you emty out your cache, in case the compressed images are still in there.
Close AOL and restart - no more .art files
Look for a program called Irfanview. It converts from one type of pic file to another... Do a search on google... it comes up with dozens of download sites.
I don't have a copy installed here at work, so I can't tell you if it does the .art files or not, but it does do dozens of other picture file type conversions to jpg, bmp, etc... -
It doesn't appear that Irfanview supports AOL's .art format, after checking the list on their website for supported file formats.
You may want to take a look at this page, it describes exactly how to convert this .art format to .jpg or .bmp, etc. Hope this helps you!
Click on this link:
http://www.members.aol.com/oldnelly77/page9.htmEthernet (n): something used to catch the etherbunny -
You could try OPEN AS under Photoshop and see if another filter will open it...
yepper, I just checked the setup on my home pc and it does not appear to have a converter for the ART files.... sorry.
If he's on AOL, he doesn't need to convert - just change his settings and download the pic again...it'll be a jpg
I can't imagine why anyone would want to keep a compressed .art file - the quality is worse than a 28k modem rm video file.
If for some reason you can't replace the pic, open the pic in aol, use your Print Screen key, paste and crop the pic in an image editing program...the quality isn't gonna be any better anyway.
How to create a BluRay from odd format videos and not distort the picture?
By Peterk312 in forum Video ConversionReplies: 5Last Post: 16th Jul 2011, 20:49 -
Album cover art
By ssaamm in forum ComputerReplies: 1Last Post: 1st Jan 2011, 09:53 -
Embedded attached picture (covert art) max size
By Brazil in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2009, 06:56 -
Is this art or a f*rt?
By M Bruner in forum Off topicReplies: 8Last Post: 20th Apr 2009, 23:22 -
Lost art
By Dv8ted2 in forum Off topicReplies: 3Last Post: 19th Apr 2009, 10:26
