i have a 1 hour 20 minute and 40 sec. video on my hard drive. i ve cut all i can cut from it... can i burn it to dvd or does it have to be 120 minutes or less?
i cant use dvd shrink because its not a dvd disk, the video is on my hard drive... its mpeg2
are there anthing i can do
what are my options ?
Results 1 to 12 of 12
As long as the file is 4.37 gb or under then there should be no problem,its not the time length of the video you need to look at,just the size.Make sure its dvd compatible and you have a dvd author program.
ok great, i was worried about the time..
the original video was 701mb avi file, i encoded it with video studio at 7000kbps, 720 480 etc, all dvd compliant but it turned out to be 5.16 gb size.. got the 7000kbps from powerbit calculator.
when i opened it in virtualdub it said the avi file had a 128 audio bitrate..
what advice or size( kbps) should i encode it aagain i dont want to keep trying trial an error, and do it over and over.
at what bitrate should i do it at? to get it to 4.37gb
thanks -
check the DVDRHelp Bitrate Calculator in the Tools section...
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
how do i use dvd shrink , i tried it but it was looking for a disk in the dvd rom? how do i use it if i m using a file?
choose open file browse to and load up the first ifo file
there isnt and ifo file, its just a mpeg2 file.. there wasnt any ifo file to add
Use TMPGEnc DVD Author or similar program to author it as i already mentioned.
LOL, Boy you just want everythring for free. Are you now using net zero to get on here and post too?
Originally Posted by diablo
if it did, just load that result into Shrink using file mode
Removing the first 18 seconds of a video
By Simmons in forum Video ConversionReplies: 9Last Post: 14th Jun 2011, 05:18 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 22:14 -
JPG to 18-hour video
By Aidan128 in forum Video ConversionReplies: 7Last Post: 18th Feb 2011, 06:21 -
Video only playing 3 seconds .mpg
By richardos in forum Software PlayingReplies: 8Last Post: 20th Oct 2010, 19:27 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum Capturing and VCRReplies: 5Last Post: 13th Jul 2007, 21:55
