  1. Hello,
    I bought a very expensive software Digital Juice, and I use it every day. Unfortunately I use a lots of DVD's and I have to manipulate those very carefull.
    My question is because I'm really concern about the scratching on their's surface, how can I duplicate my DVD with my DVD-R A05 Pioneer.
    Not in the last I would like to say that the orignal DVD's are about 8 GB each, so I need to covert or to split into 2 DVD-R 4.7 GB
    So how can I do that ?
    Thanks a lot, I appreciate your help here
  2. Something like dvdshrink would do the trick.
    Have a look in the guides section for a how too there are plenty in there, even though it is easy to do...
    Not bothered by small problems...
    Spend a night alone with a mosquito
  3. Sorry my ignorance, but I still can't find the program who can split 1 DVD Software into 2 DVD software , too.
    Thanks for being pation
    Again, I don't want to do nothing with movies !!! only DATA (softare ! )
  4. dvd shrink is for movies. nero has a backup tool that will span disks you could use that just to save it and then run it from the hard drive if you need it.
  5. Split DVD-9 to multiple DVDs: DVDFab, DVDXCopy
    Shrink DVD-9 to fit on one DVD: DVDShrink, DVD2One.
    Guides for all these programs can be found in the GUIDES section.
  6. Originally Posted by mobius_
    Mobius - Thanks, and yes I would like to run from DVD, and not from hard drive.
    andkiich - Again, the same problem, I don't need for MOVIES I want only DATA please ! Thanks though.
    Apr 2002
    Oskeeweewee Ontario
    oops, wrong link..Sorry
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Why not just copy approx 4GB of the data files into 1 directory, the rest into another and create data DVDs for each of the directories?
    If in doubt, Google it.
