I tried to cut small clips about 5 to 10 seconds long of various fishing video to join together for a movie entro later.
I used TMPGEnc Plus (The cut and join tab on MPEG Tools) and all the newly created clips are pixelated. You can see the digital blocks or the missing digital blocks of information at the beginning of each clip. Whats the fix? What other software will create 5 second clips to join later?
Thanks For Some Help!!
Results 1 to 1 of 1
creating many small clips w/ mpeg ts file
By Funkymoses in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 11:53 -
Putting lot of small clips toggeter
By red_d in forum Video ConversionReplies: 2Last Post: 7th Mar 2008, 21:51 -
Small MPeg clips From Cam
By vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jan 2008, 14:28 -
How to create small clips from a movie!
By unstopabl3 in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 04:34 -
Need help on how to author a DVD w/clips into a small section of the screen
By mbextreme in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 04:22
