can i rip one of my region 1 dvds and burn to a dvdr and it will play on my region 2 player?
In theory, IF you ripp a Region 1 NTSC DVD, change the region code to support 2,3,4,5,6,7,8, Your Region 2 PAL DVD player should allow NTSC input to the PAL playback (output).
Unlike the consumers in North America (NTSC), many PAL DVD players allows the NTSC colour scheme to be converted on the fly. the limitations is the Region Header. After you rip it to your hard drive, use IfoEdit to change the Region 1 (value 254) to either value (0 or value 64). Or you can look at a Region 2 DVD that currently is accepted and plays and just plug in the same value in VIDEO_TS.IFO file.
DVDRW 2016UI - DVD Rewriter
By DVD-Writeoff in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Sep 2011, 12:18 -
Playing a Region2 dvd on a Region1 Player
By barbudo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Feb 2011, 08:48 -
PS2 and DVD info from region1 moving to region 2. confussed totally here
By joelliott in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2010, 15:52 -
entire disc rip Drilbit Taylor Region1
By greenapple in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 03:09 -
Samsung Writemaster DVD Rewriter & Ripping DVDs
By rock_king_my in forum DVD RippingReplies: 1Last Post: 7th Dec 2007, 00:47
