i was wondering if it's possible to have background music play continuously while paging through different menus--especially switched menus.
i know switched menus are a collection of other menus, but i want to have background audio on each page and it restarts as u arrow over to each new button (ie, each new switched menu).
i'm using DVD-lab currently, but if there is another authoring program out there that can accomplish what i'm trying to do, i'd be more than happy to check it out.
thanks...sturmie
"Why is The Flash in a hot tub?"
I'm not sure I understand you corectly or not, but if you want each menu to have it's own audio, then it's a simple matter of draging an audio file into each menu.
If you only want only one song to play uninterupted while you change menus, then I don't how or if that can be done.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
yes, option B is what i was looking to do--uninterrupted audio for each "page". considering each button is a "menu" when using switched menus, i would like to have continuous audio for each page--or for all DVD selection screens if possible.
does that help?
sturmie"Why is The Flash in a hot tub?" -
Sturmie -
I don't think the dvd spec allows audio to continue from menu to menu, uninterrupted.
so it's not that DVD Lab won't do it - it's that it can't be done.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Background audio/music
By web_smurf in forum Authoring (DVD)Replies: 3Last Post: 14th Sep 2011, 03:44 -
How can i do switched menus with videos in Dvdlab pro?
By wan2no in forum Newbie / General discussionsReplies: 1Last Post: 26th Jan 2009, 00:54 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 13:56 -
How To Create an AVCD With Hi-Res Menus and Background Music
By BinaryJustin in forum User guidesReplies: 1Last Post: 3rd Sep 2007, 07:27 -
How to lower background music
By auroragb in forum AudioReplies: 3Last Post: 24th Jul 2007, 21:54
