I typically use the UDF/ISO compilation method in Nero to burn my discs. It seems to work fairly well, but screws up about every 20-25 discs. Same thing happens with the Video method. I don't think it is the discs at this point cause I usually only buy Ritek. Using DVDDecrypter, I have never had an unsucceful ISO burn, but (call me lazy) I don't like to spend the extra 5 min to make the ISO image. Is there a better program that lets you burn directly without making the ISO image?
I three gave up on Nero for DVD writing. I now use VOB Instant CD/DVD.
Not one failure. On occasion I will use Sonic Foundry DVD Architect when I am using it for authoring a DVD. Not one failure as well. -
That's odd - I have always used the DVD Video template in Nero, and I have yet to encounter a problem with it that wasn't of my own making...
I've had numerous DVDDecryptor failures, all with version .17 It doesn't like buffer underruns (I think it's a bug), in fact it it doesn't implement buffer underrun at all (verified with RW testing).
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Capturing from LaserDisc for DVD burning - best method?
By Xoanon in forum Capturing and VCRReplies: 11Last Post: 25th Apr 2012, 22:51 -
Best method for splitting up an .avi into various chapters and burning
By aple in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 20:24 -
Is there a better method?
By quxote in forum Authoring (DVD)Replies: 4Last Post: 24th Nov 2009, 15:32 -
Best burning app/method for DVD?
By stantheman1976 in forum Newbie / General discussionsReplies: 14Last Post: 25th Feb 2008, 13:04 -
no burning method
By johnthescot in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 04:54
