I am using DVD Decrypter to rip the VOB from the DVD to my hard drive.
In DVD Decrypter I am using all default settings. No problems so far.
I use Virtualdub-MPEG2 and this guide:
https://www.videohelp.com/avi2divx.htm
In this guide, it specifically states to use Video->Fast recompress and explains why to not use full processing, so I use Fast recompress.
I select Audio->Full processing.
I select Video->Compression.
For Video Compression, I have been selecting Huffyuv. I have selected other codecs but have received the same failure.
I select Audio->Compression
For Audio Compression, I have been selecting MPEG Layer 3. I have selected other codecs but have received the same failure.
I select File->Save AVI and the process runs to completion.
I have had issues with Premiere v6 crashing with the AVI's generated by VirtualDub-MPEG so based on suggestion that I received, I tried several video codecs. The results were the same in each instance. I got to the point where I thought that Premiere was corrupted. I finally tried Virtualdub with no codecs and it worked.
The following is my sequences of tests using the Fast Recompress option:
Video codec = Huffyuv
Audio codec = Lame
Result = Premiere crash
Video codec = none
Audio codec = MPEG3 Layer-3
Video codec = none
Audio codec = none
Result = sync issue
Video codec = Cinepak
Audio codec = none
Result = sync issue
Audio codec = AC-3
Result = sync issue
Video codec =Huffyuv
Audio code = Direct Stream
Result = sync issue
From this it appears that if I use the MPEG Layer-3 or Lame audio codec, Premiere will crash. I am having a sync issue otherwise but this can be addressed in Virtualdub by adding a offset in the audio conversion.
Q1) Can anyone give me input on this issue?
Q2) Is there a better way to address the audio sync issue other than the offset setting in Virtualdub?
Q3) Also, why would I not use Direct Stream in the Audio section?
Results 1 to 1 of 1
FAVC Wavi Crashes at 99% asks to be debugged
By Konfusion in forum Video ConversionReplies: 3Last Post: 15th Sep 2011, 18:16 -
Adobe Premiere Elements 7 keeps crashing
By NP11073 in forum EditingReplies: 7Last Post: 22nd Oct 2008, 01:23 -
Premiere Elements Keeps Crashing
By DrawnIntoIt88 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2008, 14:32 -
photoslideshow crashing in premiere Pro
By pantsdavies in forum Software PlayingReplies: 0Last Post: 23rd Dec 2007, 01:21 -
VirtualDub keeps crashing on me
By Odi in forum DVD RippingReplies: 12Last Post: 3rd Oct 2007, 20:52
