Ok.. I have a customer who has some video and still images on a dvd-ram, and he wants me to copy it to a +RW for him. Unfortunately I don't have a DVD-RAM drive. What would be the best way for me to go about doing this? Are there any DVD-ROM drives that will at least read this disk? Or should I just buy a RAM drive and return it when I'm done?
I'm at a loss as to what I should do.
Results 1 to 12 of 12
If I was you go to www.newegg.com buy the LG duel DVD burner that burner's DVD-RW and DVD+RW and DVD-ROM for $125.00. Look into the drive there two kind's of DVD-ROM one that only the DVD-ROm and one ina catridge format. Also panansonic might still make some drive that read that catridge formay I do not know abou the LG burner i think it only read the disc format
Both LG 4040 and LG 4020 support DVD-RAM recording and reading.
Sam Ontario -
My Aopen dvd-rom can read them so I am sure other drives should be able to also. My Lite-on does not though.
If its in a cartridge you need a cartridge reader to read it. Some cartridges let you take disks out of the cartridge & some do not.
check newegg for the toshiba DVD-ROM thats able to read RAM. runs about $32. I haven't had much luck finding them in stock lately though.
the toshiba 16xx dvd drives will read dvd-ram.
They're pretty decent drives.
some samsung madels support dvd-ram reading also. -
Do you know what type the cartrdige is
Type I
Type II
Type III
I believe Type II and III allow you to remove the discs, and they are readable in rom drives. -
Thanks for the info guys.. I bit the bullet and bought a iomega Super DVD drive. Had some trouble with the DVD-RAM that my customer had.. stupid time code errors and such.. but all is well now.
Thanks again -
I bought this Toshiba drive for $33 as seen here.
http://www.newegg.com/app/ViewProduct.asp?submit=manufactory&catalog=55&manufactory=12...tby=14&order=1
DVD Ram Drive
By gemma-the-husky in forum DVD RippingReplies: 5Last Post: 26th May 2008, 19:49 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 18:32 -
Copy recorded DVD-RAM to DVD-RW?
By Trollheart in forum MediaReplies: 11Last Post: 15th Apr 2008, 15:32 -
Is there way to copy a Dvd realtime with RAM drive like a standalone playr?
By Blumphf in forum DVD RippingReplies: 18Last Post: 25th May 2007, 07:21 -
DVD-RAM corrupted in PC drive?
By AlanL in forum MediaReplies: 6Last Post: 11th May 2007, 12:08
