I've created a VCD with still images (.jpg)
Unfortunately I've lost all of my originals and only have my VCD to go with.
Under the VCD directory there is a folder called 'SEGMENT' that I know contains the .jpg files. These pictures have been converted into .DAT files
during author of the VCD.
Is there anyway on earth to get these files back to .jpg?
PLEASE HELP...
Kindest Regards,
I've tried it this way-with having over 200 pics. this would take me two days.
Any other help out there I would be thankful. -
I've no experience of slideshow-type VCD's at all, but I wonder if this would be any help:
VirtualDub can open a video file, and save it as a sequence of images (either Targa or BMP) - one per frame by the look of things, which makes sense.
This option is under File->Save Image Sequence.
If you got them all back as BMPs, there are loads of apps that could batch convert them back to JPG.
So, is there any way you can rip/convert your VCD into an avi or mpeg file?
You'd ideally want to convert it to one frame per image I suppose, in order for the image sequence in VirtualDub to be useful. That wouldn't be hard once you've got your video file though.
VCDGear has lots of functions to convert to/from .dat files in VCDs - I wonder if that would be any use?
These are just 'shots in the dark' really - but hopefully it'll give you some ideas.
cheers,
mcdruid.
Sony Vegas Red JPGs on Timeline ?
By blewyn in forum EditingReplies: 4Last Post: 5th Feb 2012, 20:23 -
Convert back to DVD9
By BingCrosby in forum Blu-ray RippingReplies: 1Last Post: 29th Dec 2010, 07:40 -
16:9 (fake) that I want to convert back to 4:3
By robjv1 in forum Video ConversionReplies: 5Last Post: 11th Feb 2010, 01:01 -
SVCD with jpgs and wav
By gkma01 in forum Authoring (VCD/SVCD)Replies: 10Last Post: 28th Aug 2008, 09:03 -
Convert DVD back to MPEG2?
By ArthurDaley in forum Newbie / General discussionsReplies: 4Last Post: 11th May 2007, 03:02
