I don't know if this is off topic or not...
But the program Camstudio was recommended to me to record video off my PC screen. For the most part I want to record gameplay, and I want it to record as smoothly as the game plays, and look as good (I can compress later). I already know to record a region of the screen, and play in windowed mode. But I'm confused about the video recording options. I either get it to record not enough frames so that it looks way too choppy or it records it too fastly, resulting in a fast forwarded like video, but still doesn't capture every frame. AND, the video looks poor quality though I set it to highest quality.
So if anyone knows how to use Camstudio, if you could please help me out with these options? I can also tell you the video codecs I have to choose from, and I know under 'configure' the codec have their own settings as well, making this pretty complicated, when all I want to do is press record and have it record exactly like how I see the game when I play it. Ofcourse I guess it doesn't help that recording while playing slows the game down too.
Any suggestions?
Here are my codecs:
Cinepak Codec by Radius
Intel Indeo[R] Video Interactive
Intel IYUV Codec
Microsoft Video 1
DivX 5.0.2 Codec
You can see my PC specs by using the appropriate button.
Thanks.![]()
I used to laugh at those who liked to gawk at Lara Croft, until one day, when I realised I'm in love with Solid Snake! >.<
Yeah, the only problem is that Fraps is not free. The one I want costs money. And the trial only allows 15 second movies to be recorded, and you can only have it half size (not sure if that means resolution or window size). The price is not too bad, but I probably won't use Fraps enough to make it worth while.
Blackmagic Design Intensity Pro (PC GAMEPLAY RECORD)
By TommyGun in forum Capturing and VCRReplies: 23Last Post: 19th Oct 2011, 06:31 -
Gameplay and capture help
By BlueSega in forum Capturing and VCRReplies: 3Last Post: 9th Jan 2011, 07:37 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Help with recording gameplay
By shadewraith in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2010, 20:21 -
Trying to find the best way to record Xbox 360 gameplay
By Zaz in forum Capturing and VCRReplies: 2Last Post: 2nd Dec 2009, 08:12
