I had a file I couldn't open with TMPGenc, so I frameserved with Virtualdubmod. The file has encoded fine but when I try to put in to TMPGenc Author I get error messages.
The video resolution 480x480 cannot be used
The video framerate 29.7fps cannot be used with the resolution 480x480
The video GOP is too long.
What can I do?
Encode the file at 352x480 and set the `Max number of frames in a gop` to 18 frames,you find that in settings/gop structure,also make sure the audio is 48khz so it doesnt have to be reencoded.
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 17:28 -
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 11:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 16:29
