I am in Australia. I have my Foxtel cable box connected to my Winfast 2000XP Expert card and it works fine and I pay for the cable rights.
But as it only comes through one channel in the card I have to manually change the station on my box to record on different channels.
How do I have the cable channels come through multiple channels on the computer? Is it possible?
Thank you - Och
Unless your device has more than one tuner built inside then you cant,works the same way with tv`s.
Hi John,
I have the same TV Tuner, but no Foxtel. So, technically speaking, I can't help u out with ur problem.
Anyway, I want u to give DScaler a go. It's much better'n the Winfast PVR application. Although u cannot use it for recording, its gr8 for viewing TV on ur PC. It actually does full screen deint in real time. Unlike Winfast PVR which, I guess, simply skips one field.
By the way, I found a channel list for DScaler (program.txt) on their website. It has frequency settings for all Foxtel and terrestrial channels.
Regards,
Keith -
If your cable is the same as our cable, only the premium content scrambled, connect to the card before the box and try. You hould get the basic channels with the tuner.
All cable boxes change the frequency of all channels to either channel 3 or 4.
To watch/record premium, you have to reconnect the box, select channel with cable box.
Cheers,
George
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 14:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 17:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 15:50 -
HDMI cable seems worse than RBG cable
By BroomQueen in forum DVB / IPTVReplies: 7Last Post: 24th Dec 2007, 18:27
