Hi guys..
I built and burned a project this morning and it worked fine. So I started on the 2nd and in simulation mode.. everything works great. I am able to select and click button, jumps to track etc.
When I build and use Apple DVD player, my menu buttons seem to be dead links.. nothing happens.
Does not make any sense.. could it be DVD SP 2.0 is corrupting the build file?
Did you remember to draw button areas in the menus? Did you set all the links to the right tracks and options? If so, you might try Apple support, or the DVD Studio Pro mailing list.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Button's were drawn.. links all set up.. it simulates just fine.. but does not emulate one it has been built.. Ive stared at it and taken breaks from it.. thrown the project out and rebuilt it..
Now I am running DVD SP 2.0 .. don't have the 2.0.2 patch.. was there any major issues with 2.0? -
I would definitely run the updater, especially if you're running Panther. It supposedly fixes some Panther-related bugs, and is strongly recommended by Apple for all 2.0 users.
I am trying to find the update.. I can't get it from apple because I did not get 2.0 in a kosher way.. and they require a serial number..
I've been trying acquisition for a week and have not found 2.0.2 -
search for this on apple dsp forum i think others had this problem.
pants on, pants off, pants the floor. -
Warez are frowned upon here (see forum rules), but you can get it by running Software Update in your System Prefs. That doesn't require a SN. I believe you must have your DVDSP.app in your Applications folder for it to be found.
Build DVD Structure without Menus and Create them Separately
By Bruno AUgusto in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2011, 12:50 -
Encore CS4 DVD Image Build is incredibly slow
By aple in forum Authoring (DVD)Replies: 1Last Post: 22nd Jul 2011, 10:42 -
Why is Imgburn DVD Function buried under Mode>Build?
By jimdagys in forum Newbie / General discussionsReplies: 27Last Post: 1st Dec 2008, 18:48 -
CHeaper to build HTPC than buy Hi-Def. DVD player?
By ryangarfield in forum Media Center PC / MediaCentersReplies: 2Last Post: 18th Jan 2008, 14:24 -
Whats the cheapest way to build my dvd collection?
By ryangarfield in forum Off topicReplies: 15Last Post: 12th Jan 2008, 17:20
