Hi, I've recently gotten a couple of movies from thailand i wish to backup, and the movies always start with the english subtitles on. is there a way to change the defualt subtitle setting before burning the backup?
Hi,
Have u tried using DVD Shrink (www.dvdshrink.org). There you can remove which subtitles you like. I havent personally tried this but give it a go and reply here to tell me your outcome.
Cheers
Default Subtitles?
By lamprey in forum Blu-ray RippingReplies: 7Last Post: 8th Oct 2011, 21:49 -
Problem with subtitles off by default in DVDlab-pro
By blajko in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 19:21 -
Is there a way to remove subtitles?
By Onceler2 in forum SubtitleReplies: 2Last Post: 9th Dec 2009, 13:05 -
Remove SubTitles
By fredb38 in forum SubtitleReplies: 1Last Post: 14th Aug 2009, 17:55 -
how to remove subtitles?
By KittyLuck in forum SubtitleReplies: 1Last Post: 18th Jan 2009, 03:46
