My captures look fine when I'm playing them on my computer(mpeg or from disk), but when I burn them to DVD and play them on my TV I get artifacts that look like wavy horizontal lines when there is fast motion. Is there some sort of setting I can change on my TV or DVD player that can fix this? I have a JVC Progressive scan player.
Video Capture card-- Hauppauge PVR 250
Source -- Tv tuner/Composite cable to analog camcorder
Editing Software --- Ulead MovieFactory SE
Burning Software --- NTI DVD Maker Gold 6
Dvd Player --- JVC XV-N50 (progressive scan)
Computer Athlon 2.8 Barton
nForce2 MB chipset
512MB Geil Dual Channel Memory
Geforce Fx 5200 GPU, 128MB DDR, 8X AGP
Seagate SATA 200MB HD
Capture Settings: Output Stream------- Program
Bit Rate 5500 Kbit/sec (constant)
Standard Play DVD 90 min/Disk
Sounds like you're seeing interlacing which isn't being displayed properly due to your progressive scan player. It probably looks okay on the computer due to the software player you're using being able to adjust and display the interlaced video properly. I don't think Windows Media Player will adjust for interlaced video, so try watching the video in WMP and if you see the same wavy lines I think that's the problem. If this is the issue and you want to display on your progressive scan player, you'll need to reencode the MPEG to get rid of the interlacing. There are articles on this site on how to do this...just search on "interlacing".
Newbie converting old VHS tapes to digital - but get wavy/scrambled lines
By roguewarrior in forum Capturing and VCRReplies: 7Last Post: 25th May 2010, 22:16 -
Wavy lines on tv reception (tapes too!)
By JudgeGarth in forum DVB / IPTVReplies: 4Last Post: 27th Feb 2008, 11:56 -
Crazy, wavy black lines on capturing from jerky video (images&vids in p
By osteopants in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2008, 12:25 -
I recoded my VOBs to AVIs, now I have like 'motion lines' thru the video??
By lrfowler in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2007, 20:43 -
DVD rip /avi thru MTR /FFmpegX - get wavy lines
By BattyRoy in forum MacReplies: 5Last Post: 31st Aug 2007, 10:06
