Where can I buy region 1 type BLANK DVDs that will play on ANY DVD player?
I'm not talking about the RW+/RW-
Results 1 to 9 of 9
Region specific blank DVDs do not exist. A Blank DVD is just that "BLANK". YOU have to tell it in your authorizing programs what region/ regions the data is restricted to.
Thanks Dennis !!
So in the process of recording to the DVD I can program it to a certian region?
If I program it to the USA region will it play on ANY DVD player here in the USA? -
Not really, Consumer level Authorizing programs usually do not allow user intervention region coding. They usually hardcode Region 0 or All Region into VIDEO_TS.IFO. after that the only limitation is NTSC and PAL playback. Most USA DVD player are restricteed to Region 1 NTSC, but many can still play Region 0 NTSC and All Region NTSC, BUT some can not. I do not technically know the difference between Region 0 and All Region.
IfoEdit allows you to change the Region codes to other than Region 1 (254). -
And one other thing...
...I understand that some movies (already on a DVD) might be to large to copy to a blank DVD. There a 4.7 limit...correct me if I'm wrong.
But how did the studio get the movie on on the original DVD? Do they hold more/ or are larger than the the DVDs we can buy? -
As of this date, recordable DVD are limited to (DVD-5) single side layer 4.37 GB and DVD-10. Studio DVD can be issued on a DVD-5 or a DVD-9 (single side dual layer 9 GB) or a DVD-10 (dual side single layer 4.37 GB per side) or even a DVD-18 (dual side dual layer 9 GB per side). Studio DVD are not recorded/ Burned as consumer DVDs are there are pressed like a silver CD.
Currently recordable DVD-10 are only available in DVD-R no DVD+R.
There are many programs avaiable to "shrink" or "split" a DVD-9 onto a DVD-5. -
I read where the movie can be compressed to fit the DVD but it will affect the quality of the picture.
sounds like someone need to come up with a consumer version of the "press" !!
Hey Boss...how bout them Titans !! -
Well, considering Im from Boston and the patriots wooped the Titans, then YEA< HOW BOUT EM!
How to determine best quality when purchasing blank DVDs
By yznf in forum Newbie / General discussionsReplies: 14Last Post: 10th Feb 2012, 16:15 -
Blank DVDs and flashing light on the DVD drive
By timmus in forum DVD & Blu-ray WritersReplies: 5Last Post: 27th Jan 2010, 23:31 -
Advice on blank DVDs
By didikai in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2008, 23:30 -
i have no idea how to copy my dvds to a blank dvd
By kmnyc7 in forum MacReplies: 7Last Post: 4th Oct 2007, 09:34 -
Will blank camcorder DVDs bought in the US work OK on my UK-purchased camcr
By richard2006 in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2007, 14:57
