I use dvd decrypter,dvd shrink & clone dvd. I recently burned terminator 3 widescreen edition. on my dvd player i can view it in 16:9 aspect but when i play it on my ps2 it shows widescreen(4:3 letterbox) and i cant change it.
Is there any way i can burn the dvd as 16:9? if so how?
also, when i play the dvd+r on my dvd player it starts to mess up after an hour & the dvd+r is very hot, but on the ps2 it plays perfectly from start to end, why is that?![]()
P.S. my dvd player is a JVC xv-sa70![]()
i tried to . i set it up at the begining(turning it on without a cd) and while the movie is playing(select button,setup, screen setup) it cant be changed from 4:3. on some movies it works and on some it doesn't.
You will need to check the Title Set Movie Attributes for the copy of Terminator 3 you created. You will need IFOEdit for this task.
Open the .IFO file belonging to the main movie. This will open the default view called VTS Overview . Double click on the first value under Title set (Movie) Attributes. It will open the following...
... make sure that 16:9 and Automatic Letterbox is selected.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 11:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 13:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 20:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
