I dont know why but when i try to convert my video (in Xvid(avi)) it just hangs (using TMPGENce) . when i go to stop it it does nothing and makes my computer unstable! Please help me.
This happend to me many times...
First, don't use TMPGenc for XVID. It is designed for mpeg1 or 2.
Use VirtualDub Mod, it is newer and more realiable than the orginal VirtualDub....
Learn how to use AVIsynth and framserve to VirtualDub. Do not use any of the VirtualDub filters in VirtualDub, but rather use them in AVIsynth (sounds funny, but it is true)..AVIsynth has its own filters as well...
AVIsnyth can do anything TMPGenc can, faster and more stable....It is really the key to the entire problem....
When framserving, make virtualdub use only direct stream copy, becasue AVIsynth is going all the work...
Try that..It is more stable than using TMPGenc for XVID... -
This is what worked for me when converting several Xvid to MPG's.
1. VDub to extract audio only into a WAV file with no compression.
2. VDub to save video (no audio) into a new AVI file.
3. TMPGEnc Plus to encode the two files into a MPG.
4. TMPG DVD Author to compile and write DVD.
I had no problems with audio sync.
Hope this helps. -
Originally Posted by mynameis97rb
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
Encoding Xvid in 50mbps?
By 24fps in forum Video ConversionReplies: 11Last Post: 15th Aug 2011, 19:37 -
Xvid encoding
By fester77 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2011, 07:19 -
How to get Xvid encoding in VirtualDub
By Dr_Asik in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2010, 10:31 -
Quick XViD Encoding?
By shorto in forum Newbie / General discussionsReplies: 5Last Post: 22nd Mar 2008, 03:54 -
Encoding with Xvid.
By Felo in forum Video ConversionReplies: 1Last Post: 26th Aug 2007, 00:38
