Hi All, I have a pioneer dvd writer, with the latest ASPI Drivers (4.71) installed, as well as the latest Firmware update. At the minute have been playing with Bulkpaq x4 orange dvds and for whatever reason still takes between 45 - 55 minutes to copy a disk as opposed to 15 minutes. Nero is telling me that its writing at 4 speed. I`m running Xp. Any help (in simple English) would be greatfully recieved
Cheerz in advance![]()
Different software/system configurations behave differently. It would be difficult to pick out precisely what is causing your problem. It could be as simple as Nero not being ideal. If u have plenty of processing horsepower and ram, try a different burning program. Is your burner on the same IDE as the HD? If so...it can slow down the transfer of info onto the dvdr. Are you doing anything in the background when yer burning? Does a screensaver come on? Have you tried a different media to see if that helps? It could be anything.
I`ve tried using Stomp as well as different media. I can`t remember if the burner and H/D are on the same channel. I have 2 hard drives and 2 dvd drives, while I was playing with nero cd speed last night discovered it rekons that the ASPI was corrupt, I tried to replace it and it was still corrupt!
Its doin me head in
Cheerz -
You need to uninstall the ASPI driver. Reboot. Install the new Driver. Reboot.
Installing overtop doesn't mean the bad file will be overwritten.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanx Gaz, as I`m a bit thick, can you explain how I do this please
Also, if you are copying on-the-fly (from DVD ROM drive to DVD R drive), it may be your transfer rate isn't good enough and the buffer underrun is preventing the burn failing but still slowing it down. Make sure you have DMA enabled on both drives.
Problems copying Blu-Ray disc...
By waldothewonderboy in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2012, 20:41 -
IMGburn 2.5.1 copying problems
By NickiMitch in forum DVD RippingReplies: 1Last Post: 7th Jun 2010, 08:58 -
Problems copying CDs on Mac
By Nilfennasion in forum MacReplies: 3Last Post: 3rd Jul 2009, 08:15 -
Problems copying VOB files from DVD to PC
By jaekim86 in forum Newbie / General discussionsReplies: 8Last Post: 19th May 2009, 02:09 -
Anyone had problems copying Dvd's with HP drives?
By Blumphf in forum DVD & Blu-ray WritersReplies: 53Last Post: 31st May 2007, 20:40
