At first this burner was working with out flaw, but more recently Nero wont finish my DVD-R back ups, and when i Burn a CD the buffer seems to be always running out and then just at the last mintue it some back up. Same things happen and i acutally get a burn with DVD Decrypter. Also it'll no longer RIP at higher speeds, even with DSS that i got from sony.
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press
First thing to look for. Make sure the drive is using DMA mode. IF DMA mode is set, try replacing the IDE cable.
How would i make sure that it's in DMA mode, and the IDE cable is good, would that matter much
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press -
Use Nero InfoTool, free small & shucks, i wish more people mentioned it:
http://www.cdspeed2000.com/go.php3?link=download.html
Vertical lines with Pinnacle Studio 14/510 USB card
By karebo in forum Capturing and VCRReplies: 0Last Post: 11th Dec 2011, 15:54 -
Encoding Video for a D-Link DSM-510 MEDIA PLAYER
By loughary in forum Video ConversionReplies: 1Last Post: 9th Oct 2009, 21:37 -
Pioneer 510-H Won't Power Up
By groberson in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st May 2009, 00:11 -
Converting Video on a Harmon Kardon GPS 510
By markula in forum Video ConversionReplies: 0Last Post: 13th Jul 2008, 20:13 -
Sony RDR HX 510 and DVP NS 305
By SearchQuality in forum MediaReplies: 10Last Post: 16th Nov 2007, 10:41
